WD Rear Rims
Mike(WV)
02-14-2007 16:25:34
What other Model tractors use the same rim as a WD? Looking for 11x28.
JMS/MN
02-16-2007 21:55:44
 Re: WD Rear Rims in reply to Mike(WV), 02-14-2007 16:25:34
Your choices are quite limited beyond the WD. Some non-AC utility style tractors used 28 inch wheels, some I believe with the sliding rails, but your best bet by sheer numbers is to find another WD rim. WD commonly used an 11 or 12 inch tire. WD45 had the 12 or optional 13 inch tire. The 13 inch tire would not have been used on an 11 inch wide rim. I've never seen a D17 with less than the 16.9x28 wheel, but I believe that was oversize, and that standard size was 14.9 on a 13 inch wide rim. I have all three of those tractors, and all are equipped with the oversize, rather than standard tires. My styled WC has 11 inch tires, but likely is on a 10 inch rim. Every advancement in tractor size brought a wider tire to match power and traction. With 146606 WD tractors produced, it shouldn't be hard to find used, and new are still available.
farmer0100
02-14-2007 21:15:40
Tony Carabaugh sells them at tonystractors.com I have 4 new rims for my allis B, that I got from tony, and like every facet, of dealing with those folks ,including the price. they are currently listed at $ 200.00
wdTom
02-14-2007 17:35:32
Got mine from Miller Tire
old
02-14-2007 17:05:24
WD45 and D-17 for 2 of them. You can stil buy them new but they cost around $320 as per a catalog I have on hand
