WC hydrolics
MT in Walford
02-12-2007 21:35:09
I have a 1947 WC. It does not have hydrolics on it. Is there a way to put hydrolics on it?
Thanks
Mike
bigr
02-15-2007 17:45:39
 Re: WC hydrolics in reply to MT in Walford, 02-12-2007 21:35:09
I have a '41 WC that I bought from the original owner's family. The owner had many years ago mounted a loader and 3 point to the tractor. The hydraulic pump runs off of the crankshaft (similar to Ford) with a 2-way valve that you can switch so that the spool valve levers will either work the loader or 3 point. Pretty neat. All done in his garage. Narrow front now, but I'm in the process of converting it to a wide front.
MT in Walford
02-15-2007 18:33:38
 Re: WC hydrolics in reply to bigr, 02-15-2007 17:45:39
BigR,
Can you send pictures of the pump and the 3 point?
That would be a big help to me.
That really sounds neat. Where does the hydraulic pump hook onto the engine?
How did they do the 3 point?
You can send the info to me at my email
[email protected]
Thanks
Mike
bigr
02-16-2007 18:54:17
 Re: WC hydrolics in reply to MT in Walford, 02-15-2007 18:33:38
The 3 point came off of a Case tractor. The pump mounts to the crankshaft belt pulley. The tractor is in storage for the winter but I think I have a picture I can email.
Aaron SEIA
02-13-2007 05:05:24
There are 3 ways. You can buy a PTO pump out of the Northern cataloge, you can find a way to get one running off of the belt pulley, or you can find a way to run it off of the fan belt on the engine. The first 2 ways will not work when the clutch is pushed in-no live PTO. I have a WC that has been reversed with a loader that is set up with a pump running off of the engine.
Aaron SEIA
BDT in Minnesota
02-13-2007 06:27:15
 Re: WC hydrolics in reply to Aaron SEIA, 02-13-2007 05:05:24
There was also a small pump that mounted in front of the magneto that would work..Some variations were only used for power steering applications, while others were used as general hydroulic pumps...IH and John Deere also come to mind as using these pumps...
B W inmo
02-13-2007 04:50:48
WC never came out with hyd. I have seen one with after market hyd that fit in the belt pully spot didn't get any info {DAAH}off of it . Was said to work ok, but not live.
wdTom
02-13-2007 17:42:28
 Re: WC hydrolics in reply to B W inmo, 02-13-2007 04:50:48
I wonder if a D-17 pump would fit a WC? Some of them had the pump in the belt pully hole. A d-17 was just an upgraded WD/WD-45 which was related to the WC, so maybe, anyone know?
JMS/MN
02-13-2007 21:03:29
 Re: WC hydrolics in reply to wdTom, 02-13-2007 17:42:28
The D17 Series IV had the independent hydraulic pump that fit where the belt pulley fit on other D17s, but the internals were different, so pushing in the foot clutch did not stop the pump. WD, WD45, Series I, II, III D17 all had the same style of pulley drive. Definately would not work.
shagman
02-13-2007 03:56:45
The Wc never had them.
