Figuring out WD engine serial numbers
TJanak
02-12-2007 13:49:58
I am just getting started with rebuilding my WD. I know nothing about which block, heads, etc will work in combination. I have three different engines, one on the tractor and two others. Is there any way to figure out which engines I have? The three numbers are: WD300656PA, W194219G, and WD248875GA.
Some parts of each are not good and I don't know what I can combine. I also have another spare crank. How do I figure out which cranks I have, as I think they are different stroke?
What is commonly done during a WD rebuild? I remember something about the WD45 crank and increased horsepower?
Sorry for all of the questions, I really am new at this.
Thanks!
Travis
chalmersbob
02-12-2007 17:27:22
 Re: Figuring out WD engine serial numbers in reply to TJanak, 02-12-2007 13:49:58
w engine came from a wc, wd engines came from a wd. all bsdically the same engine. a wd45 engine serial # will start with 45 Bob
Aaron SEIA
02-12-2007 14:53:36
Looks like all 3 blocks are WD blocks. Easy way to tell, do they have a plate bolted on the distributor side of the block? If so...then all are WD. All internals will interchange. If you have one with a taller head, thats better. You can guess on the crank by measuring the throw with a tape. WD was 4" stroke, WD 45 was 4.5" stroke. You can spend as much or as little as you want. Think a full overhaul kit new rod/main bearings, pistons, sleeves, rings, full gaskets is about $600 or so. Make sure you change the cam shaft bushings. The cam is the main oil galley for the crank and needs to be snug. Any other questions, e-mail me or ask here. Glad to help.
Aaron SEIA
TJanak
02-12-2007 21:54:00
 Re: Figuring out WD engine serial numbers in reply to Aaron SEIA, 02-12-2007 14:53:36
Aaron, what makes the taller head better, just stronger? And how thick is the taller head in inches?
What is a good rebuild then, a WD45 crank in an otherwise WD stock engine?
Thanks!
chalmersbob
02-13-2007 19:28:35
 Re: Figuring out WD engine serial numbers in reply to TJanak, 02-12-2007 21:54:00
some of the late wd's had the tall head also, just like some had curved shifters. Bob
Aaron SEIA
02-13-2007 05:00:55
The tall head is off of the WD45. Think it flows a little bit better. I'd have to go measure mine to see just how tall it is. A good rebuild is a WD45 crank on WD45 or D 17 pistons, the tall head, and a WD45 carb and air cleaner.
Aaron SEIA
