Allis CA hand clutch removal
Greg Lasher
02-11-2007 11:45:44
I have a CA and the hand clutch is slipping. I took the final drive out today but I don't see how to get the clutch assy. out. Does it pull out, or can you drive the drive shaft out? Do I need to take it out to replace the clutch disk -- I think it would be a good idea to replace both seals since it was full of oil.
Thanks Greg
Wild Bill
02-11-2007 13:41:37
 Re: Allis CA hand clutch removal in reply to Greg Lasher, 02-11-2007 11:45:44
It just pulls out. Nothing holding it in but 50 years of rust, dirt, and various insect nests. You do need to take it out to replace the clutch disk. Better get a manual before you dig into that. Bill
Greg Lasher
02-11-2007 14:21:06
 Re: Allis CA hand clutch removal in reply to Wild Bill, 02-11-2007 13:41:37
I have an IT manual I guess that will be good enough -- can I use a slide hammer or ???t get it out -- there is nothing in there to hook onto to pull.
Greg
Wild Bill
02-11-2007 18:04:22
 Re: Allis CA hand clutch removal in reply to Greg Lasher, 02-11-2007 14:21:06
Greg, I don't think there is anything that you can hook a slide hammer to, I just grab the end of the shaft (on the transmission side) and start wiggling and pulling. I'll work loose and come out eventually. I'll take a lot of cussing though. The IT manual is better than nothing.
