govenor shaft oil line?
boberg
02-11-2007 06:04:48
I have a 39 B. is there a special nut that goes on linkage shaft for an oil line? i have no feed to the govenor could there be something else? my book shows nothing. is thread size 5/16-24. is it possible there was an oil cup instead?
Doug Barden
03-05-2007 16:40:43
 Re: govenor shaft oil line? in reply to boberg, 02-11-2007 06:04:48
I have a WD that I rebuilt, it has a point dist. but I didn't have an oil line on it when I got it. Does anyone know if it should?
boberg
02-11-2007 07:52:03
thank you Dick . is it just a 1/8 tube and compresion fitting? does that work as a hold down for the linkage are there any spacers or jam nuts? parts were stolen
Dick L
02-11-2007 08:58:23
 Re: govenor shaft oil line? in reply to boberg , 02-11-2007 07:52:03
Correct, it is 1/8" tubing. I have found a machine washer under some but the parts drawing does not show anything but the tubing nut.
third party imageLink loading="auto" style="width:auto;height:auto">">Link
Dick L
02-11-2007 07:32:09
Some one changed the governer cover from what came on it. They then didnt change the elbow that oils the rocker arms to a tee and run an oil line to the governer.
Look Below
third party image
boberg
02-11-2007 12:39:43
 Re: govenor shaft oil line? in reply to Dick L, 02-11-2007 07:32:09
thanks agian Dick. somehow the thread got bungerd
so i hade to chase them out. found the pivot shaft to be loose. do you see any problem putting a light TIG weld on the shaft itself just to snug it up? it is just a press fit correct?
Dick L
02-11-2007 13:00:52
 Re: govenor shaft oil line? in reply to boberg, 02-11-2007 12:39:43
Unlike materials. Just use loctite after cleanning all the oil off.
boberg
02-11-2007 10:59:38
