3pt.lift arms on 160 allis
bill 9
02-10-2007 10:13:15
3pt. lift arms will not go down after being used in a heavy lift
Keevin
02-10-2007 17:53:55
 Re: 3pt.lift arms on 160 allis in reply to bill 9, 02-10-2007 10:13:15
If your valves are like a 175 AC, my three point stuck up , and I took the spring cover off the valve and WD-40ed it and worked the plunger with pliers to free it up, with tractor off. Also later on it done it again and I WD-40ed it again and decided the spring was weak, so I put two flat washers behind the spring and it's worked since. I know, I need to get a new spring... Hope that's what wrong with yours.. easy fix
