190xt power director
Martin Nork
02-10-2007 09:12:20
I have a 190xt with power director problems. It will not disengage when in nuetral. It just stays in low when in nuetral. High works fine.
856 puller
02-11-2007 06:24:32
 Re: 190xt power director in reply to Martin Nork, 02-10-2007 09:12:20
it would be a goodidea to put a gauge in to confirm your problem. also i have seen some tractors with cabs that have missing, loose,or weak cab mounts than the cab moves and affects the p.d. linkage
J Plunkett
02-10-2007 17:27:42
That control valve has a free floating spool with a spring on each end to engage it one of the springs must be broken
Joe(TX)
02-10-2007 13:54:05
The first thing to do is to check to make sure the control valve is adjusted correctly so that it is centered when the hanle is centered. The linkage can be worn. The plates in the power director clutch can also be warped.
