WD45 Frame Rail Wedges
MikeRW
02-09-2007 05:32:47
I see in the past few days there are a couple of frame rail wedges listed on ebay. I took my frame rails off of my WD45 a couple weeks ago, cleaned them up and painted them. I never seen any wedges. Where do they go? If mine are not installed can i expect any additional wear and tear or possible damage by not having them? Thanks for your response.
Mike
George G
02-09-2007 15:53:28
 Re: WD45 Frame Rail Wedges in reply to MikeRW, 02-09-2007 05:32:47
You can get them from McMaster-Carr. I'm sure you can get them at other places. Here is one of the P/N's from McMaster-Carr 91573A034. I think it's around $15.00 for a box of 10.
MikeRW
02-09-2007 08:13:08
JMS,
Thanks for the info. I now see the application. I think maybe i'll put in a bid and try to pickup a few for the front engine support.
Mike
JMS/MN
02-09-2007 08:46:12
 Re: WD45 Frame Rail Wedges in reply to MikeRW, 02-09-2007 08:13:08
You could also make some- start with square bar, 1 to 1 1/4 inch square. (old pto shaft?) Angle a power hacksaw, cutoff saw, etc. Drill half-inch holes in the center of the wedges.
JMS/MN
02-09-2007 08:01:26
They go on the vertical bolts that pass through the frame rails- to compensate for the angle of the C-channel. Check on the two bolts that hold the radiator, and the two that hold the front engine support to the rails. Absence should not be a major problem, bolt may twist a bit- especially on the front support.
