Allis CA wiring
Richard Turner
02-07-2007 13:34:30
I just purchased a CA Allis. It doesn't run yet, but I'm tryin. It needs re-wiring. There's some kind of speaker wire from the coil to the battery, etc. Can someone point me to a site where I can get one faster than waiting of a manual to be sent?? THanks for your help!!
Keith-OR
02-08-2007 22:29:05
 Re: Allis CA wiring in reply to Richard Turner, 02-07-2007 13:34:30
Here is website with all wiring diagrams for Allis Chalmers C's. Also of other good info for your tractor..HTH
Keith & Shawn
ironguy
02-08-2007 03:13:49
i too am rewiring a ca allis and would like to know if it should be negative or positive ground? thanks.
Richard Turner
02-08-2007 05:27:56
 Re: Allis CA wiring in reply to ironguy, 02-08-2007 03:13:49
If it's original 6 volt, it is positive ground. I do know that much.
steve(ill)
02-07-2007 15:50:55
send me an e-mail and i will send you a drawing of a generic 1940-50 Allis 6 volt system. they were all basically the same, CA has a distributor where earlier models had a magnito, but all else was the same. [email protected]
Richard Turner
02-09-2007 13:19:01
 Re: Allis CA wiring in reply to steve(ill), 02-07-2007 15:50:55
Steve, thanks for all your help. It took only a few minutes to run a couple wires and she's cranking now. If only the nickel-sized hole in the manifold were as easy...Thanks again.
terry stewart
02-07-2007 14:26:49
if u get any info will you let me know thanks terry stewart
