CA starter ring
terry stewart
02-06-2007 16:47:52
ok ive got my CA apart now how do I get the starter ring off thanks for info
terry stewart
02-08-2007 05:15:47
 Re: CA starter ring in reply to terry stewart, 02-06-2007 16:47:52
I may have got my cart before the horse how do I get the wheel off
Ted In NE OH
02-07-2007 10:31:17
I use heat all the way arount the ring gear to expand it. Won't hurt the ring gear as installation calls for heating to 400 deg. If the ring gear is bad , who cares.
terry stewart
02-07-2007 14:24:53
 Re: CA starter ring in reply to Ted In NE OH, 02-07-2007 10:31:17
what about the wheel
Dave Anderson
02-06-2007 17:40:19
1. remove flywheel and place on hard flat surface like a piece of plywood on a concrete floor.
2. lube ring gear and flywheel edge with penetrating lubricant.
3. Using a brass drift punch of suitable size and big hammer, start tapping the ring gear off. You need to hit, see if its moving, change locations, and keep working around the circle. I would caution against doing this in really cold weather, at least warm the flywheel to room temp-DO NOT HEAT. Reason to do it at room temp is that I've heard of real cold ring gears snapping into pieces.
