WD Hydraulic pluming question, help
Scott, MO
02-06-2007 08:25:20
I bought 2 new hyd. cyl. for my wd's 3pt lift, they are dual action type with 2 ports. Since I will only be using one port(extend) Can I just plug off the other port?, or do I have to vent it? or do I have to run hoses from it back to the resevour?. any help on this? Thanks Scott.
BDT in Minnesota
02-06-2007 16:22:07
 Re: WD Hydraulic pluming question, help in reply to Scott, MO, 02-06-2007 08:25:20
Scott... keep in mind that your old single acting cylinders only displace the rod, and not the piston diameter as in the double acting cylinder...The outside of the cylinders may be approximately the same. but the double acting cylinder will require allllot more fluid to travel the same distance.....you will have the slowest 3point in the country, but it will definitely be able to lift a building...I hope your two way cylinders are rated for high presssure rating on the WD..
JMS/MN
02-06-2007 09:25:19
Another way of making a vent is what is on some gearboxes. Drill through a pipe plug, insert a cotter pin and bend over. Closes off most of the space but lets it breathe.
old
02-06-2007 09:18:14
You need vents on the end you don't use other wise air preassure will build up and give you problems. Any good tractor place will have them or you can make them your self by drilling a hole in the bootm of a pipe plug till its almost through then dill a small hole in the side till you hit the other hole. By the way its not easy to do that drilling, since its easy to miss the hole
Kklobru
02-06-2007 09:02:35
I would say venting would be ok. Don't plug them or the back side of the piston in the cylinder won't be able to breath.
