D15
leeingeorgia
02-05-2007 12:20:11
I'm looking at a d15 with front end loader, diesel, wide front, power steering. Tractor seems to be in good shape, everything works, but I've only had experience with a d14 gas. How reliable are the allis diesels? If the loader and hydraulics are decent, can this tractor handle 4x6 round bales with the loader? How much would you value this tractor? Thanks
Dave Anderson
02-06-2007 17:52:39
 Re: D15 in reply to leeingeorgia, 02-05-2007 12:20:11
D15 diesels have a rep for being cold natured, but a good diesel mechanic can usually work out the bugs. The things to look for are the usual stuff. Does it hop out of third gear? If it has power director, does it stay in high? Brakes good? The three point system, if it has the factory late system has the tendancy to back the bolts underneath out of the trsnsmission case-get under it and shake to see if it moves. Check out the toplink mount carefully lots of them are rigged/welded. That's all I can remember for now.
Joe(TX)
02-06-2007 06:49:39
My brother has a D15 diesel and has had no problems in the 20+ years he has had it. It should hadle the round bales with a good loader if you have enough weight on the rear. The front axle may be the the weak point.
cadet trooper
02-05-2007 15:53:15
Is it a series II or before? Really probably doesn't matter but as I've said they probably had one of the strongest hydraulic systems of their time. Can't tell you about the diesel engine but we had a customer with a series II that was carrying two 1500# round bales with his one on the loader and one on the 3pt hitch and crossed a creek and tore the 3pt mechanism off the back of the tractor and he wasn't really upset because he knew it was way too much for it. From what I understand the D15 has written volumes of it powers legend or otherwise.
