Slow Moving Vehicle Sign Mounting on a WD45
Toby(NC)
02-04-2007 22:09:53
Does anyone out there have any ideas or photos for mounting a slow moving vehicle sign on a WD45?
Thanks!
IBorange in TX
02-05-2007 19:27:11
 Re: Slow Moving Vehicle Sign Mounting on a WD45 in reply to Toby(NC), 02-04-2007 22:09:53
Email me, I have some NOS brackets in the box for the SMV sign..
Kent of SW MO
02-05-2007 07:56:56
No matter the type of equipment, a SMV sign should be mounted on the CENTERLINE of the equipment between I think 2 feet and 10 above ground level. Resently our State Highway Dept. MODOT had a leased Ford/New Holland tractor that was being used to mow the rightaway. It had the SMV mounted incorrectly on the left of the machine. I contactd the Highway Patrol and they even had to look up the correct mounting of the SMV.
Kent
BDT in Minnesota
02-05-2007 09:49:30
 Re: Slow Moving Vehicle Sign Mounting on a WD45 in reply to Kent of SW MO, 02-05-2007 07:56:56
For the newer tractors, where you access the tractor seat in front of the wheels, this is good..However, on an old relic like a WD45, mounting a piece of tin in a place where you have to climb over a mounted implement and drawdar is a saftey hazard in itself..That iron gets slippery when wet or snowed on. Mine is mounted in the safest, most visible place possible on that tractor...and it stays clean..
Kent of SW MO
02-06-2007 08:14:03
 Re: Slow Moving Vehicle Sign Mounting on a WD45 in reply to BDT in Minnesota, 02-05-2007 09:49:30
You check with your state highway patrol on the position of SMV sign. The position is set by highway laws which are at least passed by the state but may be federal in origin.
Kent
BDT in Minnesota
02-06-2007 23:55:01
 Re: Slow Moving Vehicle Sign Mounting on a WD45 in reply to Kent of SW MO, 02-06-2007 08:14:03
Missouri Revised Statutes chapter 307 section 127 states a minimum height of 4 feet above the roadway..also states NEAR the center of vehicle. Missouri, like some other states,also requires an emblem on any towed equipment that extends more than 12 feet behind the towed vehicle. With the cold weather lately, it may be a good time for all of us to research some of these regulations. If everyone would review their own saftey standards, it could prove worthy in preventing a crash or a law suit...that is the main goal..
BDT in Minnesota
02-06-2007 15:11:30
These laws vari from state to state, along with the laws for proper lighting..The words practical and possible play a key role in the interpitation...Some regulations say center, if possible, or left. To be absolutely politically correct under some of the regulations,you would have to relocate the emblem if you removed one dual for plowing, because the emblem would not be centered on the entire mass of the vehicle, which is defined in some rules..I found variations as so height and visibility distance requirements..An emblem two feet above the road may be of little value on a hilly road, but it is legal.. It would be impractical and dangerous to mount a piece of tin between my tractor and the controls on my mounted equipment on the WD45...My equipment is both safe and legal for my area...I spent about four hours researching the various regulations and postings relating to the SMV requirements...The lites required on the tractors vary by location also...White lites on the rear are not legal going down the roads anywhere..I see this violation quite often..So Many of the emblems in use are also due for replacement..They are faded and are of little value...The latest emblems are boasted to reflect headlites up to ten times better than the older ones. Along with the proper lighting and warning lamps, a new emblem could be the best $14 anyone ever spent...Agreed??
Kent of SW MO
02-07-2007 07:37:45
 Re: Slow Moving Vehicle Sign Mounting on a WD45 in reply to BDT in Minnesota, 02-06-2007 15:11:30
Yes, I agee. The one piece of equipment I move the most on the roadway is a Allis Gleaner C-II combine. The OEM SMV is a decal on the LP fuel tank. I was getting VERY faded so I bought a new one and mounted it below the tank on the back.
Kent
willie in mn
02-05-2007 04:18:38
Toby
Have one on 51 WD,high on left side. First put double faced hazzard lites,old truck style turn signals, at top of fenders. For the fanny flag used a piece of 3/16x 2 strap. Bolted on with existing tool box mount, gave it a 1/4 twist to get the flat facing the right direction, long enough to sit just above the flasher lite. A 1/8x 1 1/2 brace from the lite mount controls the vibration. Not original looking, but works for me
Willie
BDT in Minnesota
02-05-2007 02:53:56
I mounted mine above and ahead of the left fender. A bracket is bolted to the lower fender..This bracket has a hole in it for a tube to slide into..and has a thumb screw to tighten against the tube. The tube is about 30inches long and supports the SMV emblem...I set this one up back in 1978. I don't remember taking it off, except to paint the tractor..I keep mine at a height of about 6 inches above the fender. It has never been in the way,,If it does get in the way, there is only one thumb screw to loosen to move it...I would recommend running a trap strap from the top of the tube to the throttle quadrant...without this "vibration dampner," that SMV will shake like crazy and the bracket will crack your fender...
big jt
02-04-2007 22:58:26
Only one we have with a SMV hangs on a wire from the seat. That tractor works for a living though.
I would suggest making a bracket that would bolt to the drawbar or the slot in the platform for the PTO guard.
HTH
jt
