WD-45 mower
Kevin Blake
02-04-2007 19:17:56
Does anyone have any suggestions for mounting a mower on a WD-45? My tractor is equipped with PTO, snap coupler system, and belt pulley. I'd like to put a belly mower on it, but I've never seen one available for this model, although I can imagine that a belly mower could be rigged to be powered by the belt pulley. I don't know of any pull type mower that would work with the snap coupler system. Is my only option to purchase a 3-point conversion kit and rig a pull-behind that way?
richard o hanson
03-12-2007 13:39:26
 Re: WD-45 mower in reply to Kevin Blake, 02-04-2007 19:17:56
to eldon wa. i have a rear mt mower that mts on coupler under the tractor and need to know model # so i can get a book and a belt idler pulley.saw your picture where you have differnt models. please reply ( thank you )
big jt
02-05-2007 08:50:41
We have a wd45 with a Arts-way belly mower.
Mount kit was for that tractor. The Snap coupler gets pretty much eliminated. You remove the platform and put on the guard from the kit.
With the Live pto makes a nice mower. If you are figuring on pulling it off to do other jobs in season better get a rear mount and 3-point. Keep in mind that the wd45 is near impossible to adjust to hold a position so that rear mount mower should have wheels on all four corners.
jt
Bill(Wis)
02-05-2007 07:40:16
I found it under "Woods Equipment Company Download". The correct title of the pamphlet is "Undermount Mowers For Vintage Tractors". It's a 1.24MB download and is exactly what you'll find on the dealers rack. I suspect the mower will be pricey, though. Might be cheaper to get a good 3 point hitch for your WD and get a mounted mower. A 3 pt is nice to have anyway.
Bill(Wis)
02-05-2007 07:22:16
Woods makes belly mowers for vintage tractors. Their models use the existing tractor PTO shaft for power. They have a pamphlet available entitled "Belly mowers for vintage tractors". Shows set up for Farmall, Ford, Allis, etc.
BDT in Minnesota
02-05-2007 00:02:52
How do you plan on using this mower???....there are four major different types of mowers: brush hog type, fail type with rotating chains, sickle type and finishing type.... There are nine different possible combinations of these four groups, and they are all adaptable to a WD45...So rather than totally confuse you, it is best to find out the intended purpose of the mower.. Sort of like shoes; sandals or ski boots or joggers...they all have their place...
Sid
02-04-2007 19:45:27
Yes you can put a belly mounted mower on it. I don't know of any pull type mower that would not work unless it is too big. I wonder if you are thinking about a rear mounted mower instead. If you are talking about a sickle mower AC made rear mounted mowers that would fit the WD45. If you are thinking about a rear mounted rotary mower I think you will have to go with a three point kit as I don't know of any mounted ones that were designed to be used with a snap coupler. I suppose one could be built but have never seen one.
acd17toy
02-04-2007 19:35:28
what type of belly mower are you talking about? A C made a side mount sickle bar mower that fits the wd45. also you can put a belly mount finish mower on, both run off of the rear p t o shaft. any pull behind mower will hook up to the draw bar of any tractor.
JMS/MN
02-04-2007 19:33:10
Should be plenty of options to hook up a belly mower to the pto, and have live power to run it. Belt pulley is not live power, but pto is, via the hand clutch. Google Woods mowers- others will kick in with other options. Pull type mowers? AC#7, 80T, 82T- excellent choices with the TwinDrive system- cuts 90 degrees straight up, along with 45 degrees below horizontal.
JMS/MN
02-04-2007 19:39:18
 Re: WD-45 mower in reply to JMS/MN, 02-04-2007 19:33:10
I have a sickle mower on my WD45.----TwinWheel drive, side mount in front of the rear wheel. 80 S, for side mount..... ..S is side, T is trailing.
JMS/MN
02-04-2007 20:19:18
 Re: WD-45 mower in reply to JMS/MN, 02-04-2007 19:39:18
I also have a rear mount mower for the WD/WD45- it is a rear mount that attaches to the drawbar and rear final drives-- w/o the snap coupler. I think the model number is #3. Eldon (WA) is the guy for advice on these models.
