Alternator Conversion Mount C
texczech 1951
02-03-2007 07:21:44
I would like to mount a 12v Delco alternator on my C. There isn't much room on the side where the original generator was. I can move the alternator back to clear the lower hose, but then the shaft isn't long enough. Has anyone got any tips on this situation? Thanks.
Kip[UT]
02-07-2007 04:58:42
 Re: Alternator Conversion Mount C in reply to texczech 1951, 02-03-2007 07:21:44
I used a smaller alt. off an old Mitsubishi Mighty Max piokup. Same alt. was used on other late 70's-80's Mitsubishi products inclding those made for Chrysler; Dodge Ram 50, etc. Adapted to original gen. mounting bracket easily & plenty of room to clear the steering drag link. This is NOT a one wire alternator so needs to be wired differently, but I painted it satin black & it looks like it belongs there & it works great, even used the original fan belt.
JD hauler
02-03-2007 12:09:10
email me and I will send pics of how my c looks with a normal older gm alternator, steering is untouched or altered.
CENTAUR
02-03-2007 10:43:15
Did you consider a smaller diamater Alternator which is found on many autos in recent years? CENTAUR
old
02-03-2007 08:42:52
The one on my C is one the genny mount with a long bolt that goes through both holes and the alternator sits on the out side of the front hole. Most people bend the steering arm to get room for adjustment of the belt. Thats how my C came set up when I got it
