old tractor
mediumric57
02-01-2007 15:32:50
I am looking at an allis tractor and was wondering if anyone could tell me anything about it. The only #'s that I could find on it was on the right side of the block just under the distributer they are 03019-31 and the other set of #'s that I found was on the rear axle housing and they were aw-3835-7 (H) N. I also would like to know what it might be worth so I know if they are asking too much or not. Tractor runs great but about all I know about it. I also have a few pics of it if that would help any.
chalmersbob
02-01-2007 18:26:53
 Re: old tractor in reply to mediumric57, 02-01-2007 15:32:50
a couple of clues would be tire size, foot or hand brakes. does it have hydralics.
this will help identify. Bob
steve(ill)
02-01-2007 18:09:38
those are casting numbers, not tractor serial number. the serial number is stamped. The motor casting sounds like in migh tbe a WC or WD--- there for look on the left side of the axle by the brake rod cover. Or look on the center of the rear axle back side of the pumpkin. You might describe the tractor such as, narrow front end, c-channel frame down each side from axle to radiator, 28 inch rear wheels, seat centered on the tracor or seat off to one side, etc.
Gatz
02-01-2007 15:59:04
Can you post the pics ?
Or, send them to me, and I'll post them for you
Gatz
