WD45 optional Hydraulic valve ?
Ed Weber
01-31-2007 17:43:30
I have a hydraulic valve that goes on the back of a WD or WD45 It replaces the single aux. hydraulic outlet. It has two pipe taps going in and one going out. It has a adjustment wheel on the side to change the flow. Can anybody tell me what this valve is for, and how to hook it up? I can email a picture if you need to see it. Thanks Ed
acd17toy
01-31-2007 19:50:38
 Re: WD45 optional Hydraulic valve ? in reply to Ed Weber, 01-31-2007 17:43:30
that valve is called a transport valve. a dealer aftermarket installed item from AC. one line from pump to valve, return line from valve to filler neck on hydruliac resiavor. turn knob all the way out to use traction booster for pull type plow/disc. in to speed up lift arm action. the owners manual should cover this for the wd45's.
Ed Weber
02-01-2007 08:52:21
 Re: WD45 optional Hydraulic valve ? in reply to acd17toy, 01-31-2007 19:50:38
Thank you for the imfo. Now I got a place to start,and figure it out. Ed
