190 Engie miss
Brian WI
01-30-2007 10:25:25
I rebuilt the engine in my 190 diesel and when I start it up it misses. After it's warmed up it runs fine. The injector and head are rebuilt.Any ideas?
Jack as
02-01-2007 04:07:06
 Re: 190 Engie miss in reply to Brian WI, 01-30-2007 10:25:25
Make sure all the line are tight enough to seal completely. You most likely have a leaky injector line at the pump end. Did you replace all the seal washers on the lines? If there is a slight leak it takes awhile before that particular injector is reprimed to fire.
