wd 45 starter removal
Morse
01-29-2007 09:23:20
I need a little advise on removing a starter from a WD 45. It looks to me like you've got to remove the battery box. Any help would be appreciated.
Morse
JMS/MN
01-29-2007 13:17:48
 Re: wd 45 starter removal in reply to Morse, 01-29-2007 09:23:20
With any electrical disassembly, remove the ground strap first. Disconnect the battery wire on the starter, along with the mechanical connection. There is a setscrew with locknut-(left side?) to remove- then you can wiggle out the starter assembly. Starter nose is only a few inches long- should be able to pull it back that far. Use emory cloth on the mating surfaces to get good ground contact after reassembly.
Morse
01-30-2007 13:06:33
 Re: wd 45 starter removal in reply to JMS/MN, 01-29-2007 13:17:48
Recently I replaced the ignition switch to no avail. I then sanded both copper contacts and it still didn't work. I then adjusted the large wedge shaped copper contact by slightly unscrewing it from the starter housing to which it was attached. I didn't know that it was held in place with a nut on the inside of the housing. Unfortunately, the nut dropped inside the housing. I need to retreive the housing and get the starter rebuilt. I'll let you know how it goes. Thanks for the help. MORSE
