RINGS STUCK ON PISTONS
yorkie
01-27-2007 05:31:49
I HAVE 4 WD PISTONS THAT CAN OUT OF A STUCK BLOCK RINGS WILL NOT COME OFF PISTONS . hOW CAN I GET THE RINGS OFF WITH OUT DESTROYING THE PISTONS
Rob Hartman
01-27-2007 19:45:21
 Re: RINGS STUCK ON PISTONS in reply to yorkie, 01-27-2007 05:31:49
Old's trick works good. Also a small propane torch, heat the rings up a little to get them to expand. Use a piston ring groove cleaner to clean the ring grooves. Lisle makes them you can get them at any parts store or Farm & Fleet.
old
01-27-2007 09:40:32
Heres what I do to get them loose, but I have a wood stove in my shop so its easy. I take a can and put the piston in it then put enough tranny fluid in the can to cover the piston. Then I set the can on the wood stove and let the fluid get good and warm so far every time I have done that the rings pop loose and they are easy to get off
steve(ill)
01-27-2007 07:24:49
you take a small ice pick type tool and put into the crack at end of the ring. pry out and break the ring off in 1-2 inch long pieces. then you need a thin file- 1/8 inch and run it in the grove to get a couple thousandths of crud and corroded aluminum off. make sure the new rings slide easliy in the groove. make sure the bottom of the grooves are clean, not just the sides.
