WC in-frame overhaul questions
Rosco Sywter
01-26-2007 19:26:13
doing a inframe overhaul on a wc. i was going to roll new main bearings in also, while i was at it. they all went in good except the top half on #1 that has the thrust flange. there must be a pin to keep it from turning, so i can't just roll it out. is there any way to replace it without removing crank? otherwise i will just not replace the top half.
also, i lost my book. can anyone tell me the torque for the mains, rods, piston pins, ect?
thanks
Aaron SEIA
01-27-2007 19:28:39
 Re: WC in-frame overhaul questions in reply to Rosco Sywter, 01-26-2007 19:26:13
That one is pinned, can't be done with the crank in the block.
Aaron SEIA
gene (missouri)
01-26-2007 20:35:22
Turn - roll the crank up a bit lifting the piston in the bore with the rod cap removed. Then back up the crank. This should provide a bit of space between the main journal and rod.
You can remove the rod bolts to prevent scratching the journal.
