WD45 Clutch Pedal and Shaft Fix
MikeRW
01-26-2007 06:10:53
My clutch pedal had excessive side to side movement due to years of wear and tear. I dissassembled it, Gave the clutch pedal and shaft to my machinest buddy. He cut me a new shaft and drilled the required holes and then bored out the hole on the pedal and pressed in a brass bushing. Absolutely no slop in the clutch any more. Sweet. I already gave him a 30 pack for the last job he did for me. Not sure yet how to pay him for this one. Now if only my legs were a foot longer. For some reason I think allis figured that anyone driving a WD45 must be 6'6''.
Nathan (SD)
01-27-2007 18:38:22
 Re: WD45 Clutch Pedal and Shaft Fix in reply to MikeRW, 01-26-2007 06:10:53
I am 6' 5" 280lbs. I guarentee a WD wasn't designed for me. My legs overshoot everything.
Bob N.Y.
01-26-2007 17:38:32
I am 6 feet tall with relatively long arms and legs. I got on an Allis 180 once. I was too close to the steering wheel, but could barely reach the levers and pedals. My only thought was, What kind of ape was this thing designed for?
MikeRW
01-26-2007 12:26:38
I'm 5'7". If i move the seat forward i'm tight up to the steering wheel (or too close for my liking). I do have the adjustable pedal extending all the way. May put a 6" extention on it.
Eldon (WA)
01-26-2007 19:57:04
 Re: WD45 Clutch Pedal and Shaft Fix in reply to MikeRW, 01-26-2007 12:26:38
Mike I'm 5'7" and have no problems....are you sure your clutch is adjusted right? I have one WD that the clutch pedal has way more travel than is necessary to disengage the clutch....I push it as far as I can and it works fine.
Eldon (WA)
01-26-2007 09:16:38
If the clutch pedal is original it should have an adjustment for length also.
George R. (MN)
01-26-2007 06:40:38
Mike,
I"m not sure if the WD45 seat support bracket is the same as my CA"s. Should be three holes on underside of seat for adjustment. You might be able to gain a couple inches.
George
JMS/MN
01-26-2007 06:17:04
That's a good fix for a common problem. I like to drill and tap for a zerk as well. Shot of grease will make it last longer.
