WC belt pulley operation
MT in Walford
01-25-2007 18:27:39
Hi,
I just got a new to me 1947 WC. The belt pulley doesn't work. What do I need to do to get it to work? Any ideas?
JMS/MN
01-26-2007 06:13:29
 Re: WC belt pulley operation in reply to MT in Walford, 01-25-2007 18:27:39
If you pull the pulley assembly out far enough, you'll see a ring of holes around the sleeve. Each hole is slightly out of line with the adjacent one. You need to select a hole that, when the setscrew is tightened down, it allows the face of the pulley about 1/8 inch rotary free play. (Gear lash). If the pulley is original to the tractor, the dealer should have punch-marked the top of the sleeve, as well as marked the top of the side rail. When you find the proper location, mark it, in case you need to remove the pulley some time. To move the pulley, either shut off the engine or lock down the clutch, and follow what the two previous posters said.
Joe M(GA)
01-25-2007 18:44:08
third party image
third party image
old
01-25-2007 18:33:13
Just means its in the unengage position. You need to take the lock nut loose and then the lock bolt. Then you can slide it in so it will engage. Theres step to get it set just right which I can't help you with.
