WD auxillary hydraulic reservoir
Rock_Picker
01-23-2007 20:32:18
Since the hydraulic pump reservoir on my WD does not hold enough oil to fully lift a front end loader, I'm looking for ideas on how and where to mount an auxillary oil tank. Past experiences (good & bad) and/or pictures would be appreciated. Thanks..... ..... .RP
Dakota Dave
01-25-2007 08:26:38
 Re: WD auxillary hydraulic reservoir in reply to Rock_Picker, 01-23-2007 20:32:18
Add a "T" fiting in to the Hydraulic drain plug then place a res at the same hieght, make sure it is vented. A Round tube Several inches in diamited attached to the frame works.If you increase the fluid capacity enough that you can top out the cylinders you need to adjust the hyd pressure down. the other aproach is to change over to the Allis Chalmers small hight preasure rams.
BDT in Minnesota
01-24-2007 08:44:33
there are a few blanks to fill in... does this loader have hi pressure, single acting cylinders, if so, there should be no problem... Now, there are double acting cylinders that may not LOOK much bigger in diameter than the Allis cylinders,,but would displace about four times as much oil because they have a piston in them that goes wall to wall inside the cylinder instead of simply using the rod itself to displace oil, as the freeman cylinders do...If you have the two way cylinders on there,, even if they appear small;;;;you will have the slowest loader on earth..but, it would lift a building..
Rock_Picker
01-24-2007 06:21:51
The loader is a Dew_Eze. The cylinders are not huge, but are larger than the old Allis high pressure ones..... .....RP
John (MO)
01-24-2007 06:01:16
I`ve never really heard of that problem. Does your loader have cylinders that are different from most of the Freeman, Henderson and such loaders?
alliswd
01-23-2007 21:00:56
with the rear lift arm rams extended check the hydrualic fluid on the dipstick. i over fill mine by 1 qt, that is more than enough to raise the loader all the way up to max hieght.
