WD45 PTO Gearbox leaks
MikeRW
01-22-2007 06:27:19
On my WD45 where the PTO gear box bolts up to the underside of the tractor i get leakage. The removal and reinstallation of this piece looks pretty straight forward. Other than simply unbolting and dropping it down is there anything i should be aware of? To seal this up better should i use gasket material (paper or cork)or should i go with a permatex product. Thanks Mike
Texas Denny
01-22-2007 14:43:53
 Re: WD45 PTO Gearbox leaks in reply to MikeRW, 01-22-2007 06:27:19
Mike, sometimes it is pretty hard to get the PTO shaft off - and it must come off to do this repair. I would use paper for this gasket - even get it from Allis Chalmers would be better.
Once the PTO shaft is out of the way, the case comes down easily.
Good luck.
Dave's WD
06-06-2007 17:50:57
 Re: WD45 PTO Gearbox leaks in reply to Texas Denny, 01-22-2007 14:43:53
I just picked up a 1950 WD. Runs great and has a New Horn Loader that works super.
I have a bad oil seal on the PTO unit where the PTO Extension shaft goes on. You mentioned that is it sometimes hard to get the extension shaft off. I need to replace the oil seal but the sahft is stuck pretty good. I don't see an Extension shaft bolt or pin so I assume that the extension shaft has spun around on the PTO stub shaft.
Before I decude to cut the PTO shaft end that attaches to the stub shaft does anyone have any ideas.
