B carb
Matt L
01-21-2007 19:47:53
I took the manifold off to weld it and fix the exhaust leak. Might even try to port the intake side :) see if it runs better in the process.....
But anyways...
Does the carb have bushings for the throttle shaft? I wanna get rid of the slop ( easy fix w/o machining it and fixing it) and be done with it.
Im gonna order a full carb kit and was just curious.
RustyFarmall
01-22-2007 07:27:48
 Re: B carb in reply to Matt L, 01-21-2007 19:47:53
A complete carb kit should come with a new throttle shaft. The new throttle shaft will compensate for most of the wear, but new bushings may be needed also. Sometimes the new throttle shafts are oversized enough that you need to polish them down a bit with some emery cloth. New throttle shaft bushings are available for the Marvel-Schebler carbs. Don't know about a Zenith, but maybe could be modified enough to work?
