D-17 tach
Hossman
01-20-2007 19:29:25
Could any you fellas out there tell me if I can get a d17 tach repaired or purchase a replacement anywhere, possibly could there be some one who restores these? Mine worked fine till the first big snow we had at the first of dec. I was plowin snow with the ol gal and kep hearin a whirin noise coming outa the dash board area, well i just figuired must be on account of the really cold temps and would check it out later. Since I was lookin back alot while usin the 3pt blade never noticed tach actin up till i was done plowin, well i smelled somthin burnt and then seen the tach needle was broke and had been rubbin on the face of tach makin the noise.I then removed the plate under the tank to check things out and found thespeedo, tach cable had came almost unscrewed and the down pressure of it tiltin back caused the needle to tilt back into the face and smoked it. Any suggestions would be great, thanks alot. Hoss
Skyhighballoon(MO)
01-20-2007 20:57:18
 Re: D-17 tach in reply to Hossman, 01-20-2007 19:29:25
Norm Steinman can take care of you.
12 S Main Street Bourbon, IN 46504
Day: 574-342-4545
Evening: 574-342-4668
Good luck! Mike
