WD 45 specs
Jon from WI
01-19-2007 21:34:21
Forgot to ask on my last post-what HP rating does the WD 45 have, and how much heavier is it than the 8N? Just looking at compairing the 2. Thanks again, and I look forward to reading your replies.
Kevin Blake
01-21-2007 15:27:06
 Re: WD 45 specs in reply to Jon from WI, 01-19-2007 21:34:21
If you think about it, the wide front ends are made so that the front wheels can lever up and down on either side. This gives a smoother ride in front. Keeping in mind that that wide front isn't adding force from the downside front wheel in a slope situation, you're already in a whole heap of trouble if it starts to tip that far and the front end has to help you out holding you up. I've been using my narrow front WD-45 with a loader just fine. Keep it low, keep the tractor aligned with the hill, and keep in mind that the best piece of safety equipment you have sits between your ears.
Ken L.
01-20-2007 05:12:01
The Allis has around 40 hp. If no additional weight was added to either tractor, the Allis will be a fair amount heavier than the Ford. To add to the narrow front question from your other post, to me, the safety factor between a narrow and wide front is in the operator. Use commom sense and you won't have a problem with the narrow front. I have driven many of each and only had a close call once. That was with a wide front. The cause, stupidity!
