S# for B
kyhunter89
01-19-2007 14:37:11
What is an Allis Chalmers S# CE81323G, possibly a B.
steve(ill)
01-19-2007 18:41:24
 Re: S# for B in reply to kyhunter89, 01-19-2007 14:37:11
with the motor number-- the CE means it is the 125 cubic inch motor with 3-3/8 bore. the 81xxx is the number of motors made up to that time, and the G stands for gasoline motor.-- russ is right, look by the shift lever for the tractor number.
steve(ill)
01-19-2007 18:41:00
russ1
01-19-2007 14:43:58
The number you listed is the engine number. The serial number is in front of the shifter embossed on the housing. If it starts with a B it is a B. If it starts with a C then it would be a C.
