WD-45 Crankshaft bearings
tractornutjd
01-18-2007 03:54:27
Hello! I am looking at a WD-45 that has spun #3 & #4 rod bearings. My question is the main bearings seem to be shim adjustable(babbit?). I have heard of these being replaced with inserts that are not adjustable. Any truth to this? I know I will have to pull the crank and get two new rods and bearing set. Thanks in advance
B W inmo
01-20-2007 04:11:01
 Re: WD-45 Crankshaft bearings in reply to tractornutjd, 01-18-2007 03:54:27
First thing if you know that the two bearings are out is to mike the crank see if it is true, may need new crank. Now you can get bearings & all other parts needed.
BDT in Minnesota
01-19-2007 09:49:54
The main and rod bearings on that tractor are all shim adjustable bearings with inserts..The first step in repairing is to determine what happened, and why..Has this tractor been """worked on""" recently??
