WD-45 Governor
Phill Snartland
01-16-2007 10:54:53
Hi All,
The governor on my WD-45 is acting a bit hesitant. It won't go up to full RPM's when it is put under a load. You can still move the carburetor throttle rod to open the butterfly all the way. I found this out when hooked to a prony brake at the WMSTR show in Rollag, MN this fall.
Is rebuilding the governor a difficult job? Can I do it myself or should I let a pro do it? While I have it apart, what would I have to change to make it operate like the D-17? I've been told that the only difference between the 2 engines is that the governor on the D-17 spins the 226 motor at 1600 rpm's instead of the WD-45's 1400.
Thanks for your help everyone. I sure get a lot of good ideas from this site!
Phill
BobinKY
01-18-2007 12:46:30
 Re: WD-45 Governor in reply to Phill Snartland, 01-16-2007 10:54:53
Changing the weights in the governor is a piece of cake. I did it and I can assure you I am no mechanic. Just pull it apart and you will see what needs to be done. The weights are hooked in by one pin which is easy to get in and out. Use your service manual and you should have no problem.
wdTom
01-17-2007 18:30:23
You can get governor parts from AGCO. If you take it apart I think it will be obivious where wear is. Be carefull putting the pins in that the weights pivot on. If the little snap rings come off the pin willfall out and destroy your new governor. Check all linkage to see if it is moving as far as it should be too. Adjust linkage as book says.
