B/C PTO and Belt Pulley Oil Seals.
Cletrac68
01-15-2007 19:37:30
I am replacing the PTO and Belt Pulley shaft oil seals on my 1944 Allis Model C. The PTO shaft is 1-1/8" and has a "oil return groove" I have not removed the belt pulley shaft seal, but assume it may be the same. Does any one have the part numbers for these seals. Read some where about a leather style seal was neccessary for the 'oil return groove' shafts. Thanks.
Cletrac68
01-19-2007 17:36:56
 Re: B/C PTO and Belt Pulley Oil Seals. in reply to Cletrac68, 01-15-2007 19:37:30
Correction new ACGO P/N for belt pulley shaft is 70225450. Sorry 'bout that.
David Maddux
01-17-2007 10:44:45
Rod: I don't mean to cause a problem here, however I think you may have two numbers transposed on that pulley seal. You said cr13685 and I think you meant 13865. I hope I havn't confussed anyone but this needs to be double checked. Dave.
Rod (NH)
01-17-2007 12:27:49
 Re: B/C PTO and Belt Pulley Oil Seals. in reply to David Maddux, 01-17-2007 10:44:45
Hi Dave,
You're not causing a problem. You are correct. I checked my website and that reference is the proper CR13865. When I made my post, I incorrectly typed that as CR13685. My mistake. Thank you for bringing that up. I would hate for anyone to purchase a seal on my say so and find it wasn't the right one. My apologies to all readers.
Rod
Rod (NH)
01-16-2007 05:12:02
Hello,
On my '42B with a 1-1/8" pto shaft I was able to use a rubber lip seal (National #450162) even though the shaft had the spiral groove. I was able to position the seal such that the sealing point of the rubber lip was located just outside the end of the groove. I couldn't do that with the belt pulley seal where the shaft also had the groove. For that I used a speedi-sleeve and a rubber lip seal. You can see how I installed those here. The seal is Chicago Rawhide #13685 and the speedi-sleeve is Chicago Rawhide #99138.
third party image Rod
Cletrac68
01-19-2007 17:26:04
 Re: B/C PTO and Belt Pulley Oil Seals. in reply to Rod (NH), 01-16-2007 05:12:02
I stopped at my local AGCO dealer and ask for PTO seal Allis Chalmers P/N 206538. The AGCO P/N is 70206538 (he had it in stock). Turned out to be a National Seal 450162. Also asked about Allis Chalmers P/N 207993 (oil groove belt pulley seal). His AGCO P/N is now 7022450 - Parts book indicated use for 'oil groove shaft'. He had that in stock also - in the package was National Seal 450444S60 - the rubber inside is very wide (about .375" when flatten out). Seal has metal case on both sides and is over 1/2 wide. Same ID and Bore as #13865 seal you mention. I am going to install w/o speedi-sleeve and see how it works out. Thanks for the input.
Cletrac68
01-19-2007 17:53:39
 Re: B/C PTO and Belt Pulley Oil Seals. in reply to Cletrac68, 01-19-2007 17:26:04
Correction - Belt pulley shaft seal is AGCO part number 70225450. (current number)
