wc motor
mawc
01-13-2007 19:55:35
I am getting new bearings for my rods and crank the crank miked out within specs so didnt have to be turned down but i m putting new bearings in it . my question is about the shims should i just put the old ones back where they were or buy new shims and start with 4 on each cap.
TxAllisMan
01-13-2007 22:47:37
 Re: wc motor in reply to mawc, 01-13-2007 19:55:35
third party image
You need to use plasti gage to check the crank shaft bearing tolorances.
You need to start with as many shims as posible and reduce the amount until you get within specs for the bearings.
Even thought the crank checked standard did you have it polished?
If you miced the crank yourself you need to be sure your mics are set properly.
All t takes is a set of rods or mains to be shimmed wrong and its going to spin/gauld a bearing.
Link
wdTom
01-17-2007 18:35:42
 Re: wc motor in reply to TxAllisMan, 01-13-2007 22:47:37
You need to have proper bearing "crush" Look in archives on how to set bearing clearance and crush. ITT book and Allis book also tell how. If plastigauge says too much clearance you must file bearing edges and reduce shims. Shims should allow for a few thousands of compression on bearing shells. That is basically it. But you need details. It isn't as simple as bolt it together. You can spend hours doing it RIGHT.
