Mower for the B
Matt L
01-13-2007 16:05:52
I might have a belly mower for my B. Its on farmall b or a currently.
How hard would it be to adapt it to my B?
Cletrac68
01-25-2007 16:27:08
 Re: Mower for the B in reply to Matt L, 01-13-2007 16:05:52
Matt,
I just did the same thing for an allis 'c'. The website is woodsequipment.com. Then find the manuals page (as a pdf file) If you can't the correct one email me back. I can attach the manual as file.
Jim R.
Dakota Dave
01-16-2007 08:19:20
You can still get the parts from Woods. You might want to order real soon though. It took a while for them to make mine. If i rember it was about 6 weeks to get after I ordered.
Joe St.Clair
01-16-2007 07:03:49
I have all the hardware for attaching an L59 to a C. I have everything EXCEPT the mower. My Uncle needed the mower. I would be interested in selling all the mounting hardware for a Woods.
Let me know if you are intereste.
Joe
Matt L
01-16-2007 11:00:54
 Re: Mower for the B in reply to Joe St.Clair, 01-16-2007 07:03:49
Of course im intrested - after Im 100% on getting the mower - owner hasnt decided that he wants to give it up - its been sitting for 5 years.
He might need money it sounds like :D
BDT in Minnesota
01-15-2007 20:09:12
I have my parts list for the Woods L306 that I mounted on my CA back in 85. ....Some of the Woods drive kits used a pulley mounted on the pto shaft, but the CA application uses an 8" or 10" v belt pulley in the place of the flat belt pulley....Either methiod will work..The kit was about $365 in 1985, but that included the belt and skids and alot of parts that you allready have..It shouldn"t be too hard to redo the IH mounts to fit an Allis... The drive belt alignment and belt length may be the only factors that may cause a problem..depending on how the IH drive was set up; you may be able to make use of the drive components you already have...If Ya can use some pictures of my CA and a copy of the Woods manuel, just drop me a note. bdt
Cletrac68
01-15-2007 19:48:49
For a "B" Woods rear mounting frame is available. Woods P/N 9376 and rear drive pulley is P/N 7451. You can go to the Woods webpage and find all the old manuals for putting the L59 (5 foot) mowers on older tractors.
Matt L
01-15-2007 18:37:48
That would be nice to just order the stuff I need most.
Or what would be nicer, in a few months is someone have the stuff for sale. I could sell the IH later to someone that needs to it too.
old
01-13-2007 16:56:55
Probably not all that hard to do as long as you either can find the right brckets for mounting it or your able to make them
Matt L
01-15-2007 15:55:10
 Re: Mower for the B in reply to old, 01-13-2007 16:56:55
I'll get all the brackets off the IH and go from there.
I was almost thinking of seeing about buying new ones from woods if there availible.
1755
01-15-2007 18:13:55
 Re: Mower for the B in reply to Matt L, 01-15-2007 15:55:10
Woods Still maid brackets to put belly mowers on CAs afew years ago but the parts had to be orderd individualy if you look at some tractors that have belly mowers you will see that if you have a way to do the work there is not much to them
1755
01-15-2007 18:13:11
