Governor Spring
gary case
01-12-2007 07:10:15
would a to strong a spring or to light a spring cause backfiring when taking off or any other backfiring?
gary case
01-13-2007 11:38:41
 Re: Governor Spring in reply to gary case, 01-12-2007 07:10:15
lol yeah, the second set. No wonder they were only .99 J8C
B W inmo
01-13-2007 03:48:58
Gary, That can also be lean fuel,points, crossed wires or weak fire, have had any one of these to be the culpert.
gary case
01-12-2007 11:09:55
hi Jerry. this is the same AC B that was popin. Still does,i just thought that might have something to do with it. You suggested a valve job if all the other things don't work. They don't work. I'm waiting on a rebuild kit for the carb. And if that isn't it, gov bearings wore or possibly a valve job needed? That's not my cup of tea. Never did go inside the motor of anything.Guess i better get some help
old
01-13-2007 12:04:24
 Re: Governor Spring in reply to gary case, 01-12-2007 11:09:55
I'd still almost bet you have a carb problem. I've been there 2 many times on my C and have to do the carb spray trick off and on on it. But the way the weather is here now I will not worry about any of the tractors for a few days, unless a tree falls over the road then I'll have to get pushy with the tree
Jerry Coulter
01-13-2007 07:28:49
You didn't put new Champion plugs in it, did you. They are "yesterday's" premium plug. I'll say no more for fear of reprisal.
Jerry Coulter
01-12-2007 07:34:17
No. More likely it is bad spark plugs/wires or worn bearings affecting the dwell in the magneto or distributor.
