WD45 Clutch and Brake Pedal Shaft
MikeRW
01-12-2007 05:42:35
The foot clutch pedal on my wd45 is very sloppy to the point where the pedal hits the side frame rail. Without looking at it closely it appears that the shaft that the pedal resides on could be simply replaced. Is this shaft available. I didn't see it on any of the parts sites. Maybe available at a dealer? Anyone know how much. I also have a buddy who's a machinist who has volunteered to bore out the clutch pedal and make a bushing insert to help the problem. Is this the way to go. Any pointers from the group thats been there will be appreciated. Thanks, Mike
JMS/MN
01-13-2007 11:08:41
 Re: WD45 Clutch and Brake Pedal Shaft in reply to MikeRW, 01-12-2007 05:42:35
Have your buddy drill and tap for a zerk fitting as well.
Butch(OH)
01-12-2007 06:54:03
It"s been too long since I did mine to give you exact shaft size info but it is a common size. You cut an off the shelf shaft to the right length and drill blind holes for the set screws and holes on the end for cotter keys, thats all there is to it. Take the old shaft to your buddies so he can match the locations. With bushed pedals your back to new.
