Allis C or CA
CSKat
01-11-2007 19:06:03
I have an Allis tractor Im confused about whether it is a C or a CA. The Tractor # is C15406. I have been told that the letter in front of the number is the model. However the tractor came with the CA on the hood. Is there any way I can determine what this is for sure.
steve(ill)
01-12-2007 15:14:46
 Re: Allis C or CA in reply to CSKat, 01-11-2007 19:06:03
yes the CA pan seat or any other pan seat can be adapted to fit the model C. basically the CA is a "newer " C. most parts with interchange except putting the big CA hydraulic pump on the C housing. You could hcange the entire housings. They have same engine, radiator, torque tube, etc.
steve(ill)
01-11-2007 19:58:54
biggest difference on the CA is it has a 4 speed transmission, the C has a 3 speed.... other updates to the CA, it has spin out rear wheels, alxe housing (final drives) tipped toward rear a few degrees, spring loaded pan seat, distributor ignition, floor deck over the transmsion, 4 piston hydraulic pump instead of 2, bigger diameter hydraulic cylinder, normally has a axle clutch on the right side of seat
Matt L
01-11-2007 20:12:59
 Re: Allis C or CA in reply to steve(ill), 01-11-2007 19:58:54
Can the CA pan seat be put on a B?
ed in cny
01-12-2007 11:54:31
 Re: Allis C or CA in reply to Matt L, 01-11-2007 20:12:59
I hace a pan seat that is mounted on the b I have right now. It bolts the two blots on the torque tube just front of the rear axle. I am going to replace it with the corredt seat that should be on it at some point. I may consider parting with it if interested.
CHALMERSBOB
01-11-2007 19:47:19
CA HAS SPINOUT RIMS AND TWO MOUNTS THROUGH THE FRONT GRILLE ABOUT WHERE THE CRANK HOLE IS. BOB
TxAllisMan
01-11-2007 19:17:27
The serial number is located in front of the shifter. Yours being C15406 makes it a C.
Damon
