Starter problems
Jim Hunter
01-10-2007 17:48:10
Have a 47 model C with Autolite starter. It cranked over a couple of times and then quit. Between the starter case and terminal using jumper cables and a good battery I get a good spark, with ohm meter it measures a short. Can I replace it with a delco starter.
Jim Hunter
01-11-2007 13:39:33
 Re: Starter problems in reply to Jim Hunter, 01-10-2007 17:48:10
Took it to autoparts store - it checked bad
Can I replace it with a delco starter. (I need a new starter switch too.)
Texas Denny
01-11-2007 06:17:17
Jim, a friend called me before Christmas with exactly the same issue. After giving him the name of my electrical rebuilder, I told him about how durable these starters were and offered to come over and look at it. Upon arrival, I loosened all connection from the battery to starter and battery to ground. None of the connections looked bad though he did have one cable that was too small. I cleaned all of the connections thoroughly - some required a file. I reassembled and she cranked right up. It took about 5 minutes. His C now starts everytime.
old
01-11-2007 10:28:31
 Re: Starter problems in reply to Texas Denny, 01-11-2007 06:17:17
Texas, I got a call like that yesterday. A friend has a Case 580B back hoe and he said his solioniod was bad. The soliniod was cracked so I did replace it for him but that didn't fix his problem. I cleaned the battery cables where they hooked to the battery and fired it right up. Funny thing is that I forgot to bring the key for his 580 with me, ya I have keys for more then half his tractors. So any how I just jumpered the soliniod to get it started and then moved the hay he had also ask me to move for him. I just love them diesels and being able to start one up with out needing a key to make them run.
old
01-10-2007 18:43:57
First off I would take in to an aito part store and have it checked. Most will do it for free. Those starter also do like to jam on the flywheel and when they do the engine will not turn over and will even seem locked up. My C does that off and on all the time.
