Piston Removal
Ted Nack
01-09-2007 19:35:40
Does anyone know if I can pull the pistons and put them back with out having to send my 1950 Allis Chalmers WD to a machine shop? We are hoping to be able to fix the piston rings, etc. ourselves. The engine has been knocking and we finally started fixing it. While I was working on it I noticed some antifreeze dripping down out of the 4th cylinder. This is our problem.
Harry J. Case
01-10-2007 18:08:52
 Re: Piston Removal in reply to Ted Nack, 01-09-2007 19:35:40
Hello Friends Does anyone know of a reasonable deal on the sleeve O rings, the friendly neighborhood Agco dealer gets $8.00 each in my area. Thanks, Harry Case,Moline,Allis nut
Ted Nack
01-10-2007 15:26:24
Thanks for the insight. We found the knocking. All of the bearings are going to be replaced and yes we do need to remove the sleeves. It should be a pretty basic project as long as it doesn't get out of hand like other projects tend to do.
Texas Denny
01-09-2007 20:13:04
Ted, it is a fairly common practice to put new rings in an engine without reboring the block and buying new pistons. For an engine to be a good candidate for a successful rebuild without reboring, the cylinders should have no score marks and measure within the mfg spec (usually form nominal to 0.007 over). Considerable improvement can be gained even if the diameter has worn past these figures, although the life of the rebuild will be reduced. When replacing rings, it is best to have a ridge ream to clean up the very top of the cylinders. If the ridge is not too severe, a good hone can improve the ridge sufficiently to allow rings to pass without damage. You will need a hone to clean up any slight surface differences and to rough up the cylinder surface. A cylinder that has been honed usually seats rings faster. You will also need a rign compressor to put in the piston after being re-ringed.
Since you have knocking, you must figure out where the knock originated. If it is crank bearings, you may need to resurface the crank which will require machine shop service and all new bearings.
Since you saw antifreeze in the bottom end, the o-rings at the bottom of the sleeves will need to be replaced. You can build a puller. Some have sucess with a soft aluminum block and a hammer getting them out. Some auto stores like NAPA will rent you a sleeve puller. I made mine with some blocks of aluminum and an all-thread 3/4" rod. If the rings are good upon examination after removal, there is probably another problem such a a cracked block.
And if you need rings, the valves will probably need attention. If they are in good condition, a good cleaning and lapping in with valve grinding compound may suffice. If the guides or valve stems are worn past spec, they should be replaced. If valves or seats are burned, they need to be replaced. Machine shop again for seat replacement.
Good luck.
old
01-09-2007 20:01:48
If you use a ridge reamer and the other correct tools you should be able to do it your self. Only reason for the ridge reamer is if you try to pull them with out useing one you can brake rings and maybe not even get the pistons out
