plugs
john morris
01-09-2007 05:06:38
I notice on my "C" that there are bushes fitted between the spark plugs and the cylinders, my "B" does not have these bushes fitted !!!! is this normal? I was wondering if they had been fitted so that long reach plugs could be fitted in place of short reach plugs.But on saying that I have fitted short reach and she starts and runs well.
Kip[UT]
01-11-2007 08:52:31
 Re: plugs in reply to john morris, 01-09-2007 05:06:38
We've had very good luck with Autolite 295 plugs on all our magneto fired A-C's. Bs, Cs, & WCs.
BCnT
01-09-2007 05:19:07
are they closed on the end going into cylinder except for a small hole??? could be a ''foul point''
they were used on engines that burnt oil to keep plugs from fouling out...if you have overhauled the engine,take them out...they do hurt power
john morris
01-09-2007 08:32:50
 Re: plugs in reply to BCnT, 01-09-2007 05:19:07
Yes thats right, they have a small hole at one end. Out of interest what plugs do you use ?? I got NGK B6S fitted and she is very difficult to start, I was wondering if a different plug might make a difference.
BCnT
01-09-2007 16:29:14
 Re: plugs in reply to john morris, 01-09-2007 08:32:50
i dont own a B or any other Allis gas engine but i've read on here alot of folks use AC plugs especially if you have a mag ignition...try pulling the foul points out and see how it starts...should be easier...if not run a compression test...chances are if engine is burning that much oil the compression rings are shot too...low compression will make it a bear to start...if it does at all.
