Allis C add on that I've done. Pictures sort of
old
01-08-2007 12:26:53
I just posted a few pictures of my Allis C in the tractor photo area, the complete tractor and also pictures of the 3 point in the parts and pieces area. Take a look and see what you think. I keep it up with adding things to it and it may not have to power to pull its self. I also have a belly mount sickle mower thats not on it right now but can be put on with out removing the front lift or 3 point
LWD
01-11-2007 01:11:10
 Re: Allis C add on that I've done. Pictures sort o in reply to old, 01-08-2007 12:26:53
mr.old,,,I think your snow blade will be to far back, the front will want to lift on ya, and if you have much snow and set the blade on a angle the front end will slide side ways on ya. why not put the blade on one of your fords? it is good you keep the draw bar on for serues pulling. and by the by dont pull trees or brush with a ford 3 point, they will go over backwards,,,,, have a good new year.
old
01-11-2007 09:09:46
 Re: Allis C add on that I've done. Pictures sort o in reply to LWD, 01-11-2007 01:11:10
That rear blade isn't for snow but to give me the weight I need for traction. The front lift is there for a 7.5 foot snow blade I have, but I needed more weight on back or all I do is spin in snow. As far as stumps I don't pull with any thing from the back. I have no need to with haveing 3 machines with front end loaders plus haveing a bak hoe. Stumps don't stand a chance with that backhoe and or my dozer.
TxAllisMan
01-08-2007 21:52:21
Thanks for posting the pics Old.
Now I have a better idea of how to make my three point lift.
Damon
N.E. Texas
C #552
Keith-OR
01-09-2007 00:49:04
 Re: Allis C add on that I've done. Pictures sort o in reply to TxAllisMan, 01-08-2007 21:52:21
TxAllisMan, here is a picture of the 3pt I built for my C. Somewhere I have all the measurements on a photo that that I printed out.HTH
Keith & Shawn
My 1948 Allis C
third party image
old
01-08-2007 22:05:26
Drop me an e-mail if you want more pictures of it. O know those aren't real good. I can take more of it and that way you might be able to see more of how I did it. I now get to make another one for my friends C but that one I have to make from scrach
Matt L
01-09-2007 10:47:53
 Re: Allis C add on that I've done. Pictures sort o in reply to old, 01-08-2007 22:05:26
Bleh.....
Now ya got me thinking I NEED a point for my B
I should just put my to30 together and run it - since it hasa factory one, but it needs more money to run - mostly lil stuff like head studs.
I was thinking of just going this route for my B>Link
>Link
old
01-09-2007 13:54:22
 Re: Allis C add on that I've done. Pictures sort o in reply to Matt L, 01-09-2007 10:47:53
Well the nice thing about the 3 point I built is that ALL the parts where just laying around any how so all I have tied up in it is time and a little power that was used for the welder and of course the welding rods. Guess thats whats so nice about haveing 30 plus tractors around and 5 or so of them are parts tractors
Keith-OR
01-09-2007 17:43:38
 Re: Allis C add on that I've done. Pictures sort o in reply to old, 01-09-2007 13:54:22
Hey Rich, you wouldn't believe it but everything you see on this 3pt was in my iron pile, except the ball swivels(4) on the ends of the lift arms. If I had it to do all over, I would just buy new Ford lift arms ($80.00 for two). Cost of building was $10.00 ea for swivels, plus the 1/2X 3 inch flat iron stock... If I had to buy flat iron the total cost would have been more than buying the Ford arms.
The U metel on ea end of my adjusters were made from 2x4 tubing. bottoms I cut tubing 1 1/2 wide then cut buttom end off, top I cut the 2x4 tubing 1 1/2 wide then cut these in half. Just need to make use of everything one has on hand!!!
Keith & Shawn
Matt L
01-09-2007 17:34:05
30 plus tractors???? Im offically jealous.... and my 3 arent even close to 30..... .
I can see how you have more tractors and all since ur like way older and collected a few more years then me.
old
01-09-2007 18:16:07
 Re: Allis C add on that I've done. Pictures sort o in reply to Matt L, 01-09-2007 17:34:05
You might be surprised if I told you my age. I've had a few tractors since 1980 but in the last 4 yers or so I went from haveing 5 or 6 up to the 30-35 I have now. If I hadn't sold a few that I had the number would be between 40-50 of them. I have 2 or 3 of them I built out of 2 or 3 other tractors and made 1 or 2 good ones from the 2 or 3. The C I just put the 3 point on was made from 3 other Cs and thats why I have parts for them that I sell. I make just enough from selling parts to be able to keep another tractor from being cut up for scrap iron which 5 or more would have had happen if I hadn't got them. Have you gone to the web site?? And if you did go did you find all 3 pages that have tractors on them??
Matt L
01-09-2007 19:33:59
 tractor stuffs in reply to old, 01-09-2007 18:16:07
Of course I looked at all the pics of ur tractors - cant resist old iron. :D
Im kinda the same way with collecting other rigs. I think Im up to 15 dodges, '55 coe IH , toyota truck 2 GM cars, 4 coots, a rokon and my ktm 500 - might have more stuff but i'd have too look
Harry J. Case
01-10-2007 19:18:59
 Re: tractor stuffs in reply to Matt L, 01-09-2007 19:33:59
Hey Matt Tell us about those Dodges you are collecting. Also are you parting any out? Looking for a 271 hemi to replace a broke block in a two ton 1956 wrecker. Thanks, Harry Case,Allis ,Moline nut
Matt L
01-12-2007 15:13:44
 Re: tractor stuffs in reply to Harry J. Case, 01-10-2007 19:18:59
I have a 57 d 500 im prolly gonna part - its got a 354 - the hemi aint mine tho
old
01-09-2007 19:48:54
Shoot you should see the cars and trucks I have laying around here. I have 4 tandem axle trucks and 3 single axle 2 tons or there abouts and then 15-20 cars and trucks.
Matt L
01-09-2007 23:19:38
 Re: tractor stuffs in reply to old, 01-09-2007 19:48:54
Looks like ur gonna have to post more pics on your site :D
old
01-10-2007 10:46:56
 Re: tractor stuffs in reply to Matt L, 01-09-2007 23:19:38
Most of the cars/trucks are more or less scrap iron, and or parts. Very few are worth tring to ever fix up again
Keith-OR
01-09-2007 17:54:30
Hey Matt, I use to spend a little time in your area. My folks managed a trailer court on Martin Way. They moved to Pacific Beach and managed an apt. complex. My cousin (dad's Nephew) was the Commander of the Navy base there.
Keith & Shawn
Matt L
01-10-2007 17:34:50
 Re: Allis C add on that I've done. Pictures sort o in reply to Keith-OR, 01-09-2007 17:54:30
At faragut? - I wanna job there so I can buy more tractors
TxAllisMan
01-09-2007 12:49:31
Nice looking lift Keith.
Also great looking pic and heck of good restoration also.
Have you used the three point on anything yet?
Wish I had the adjustable wide front also.
Damon
N.E. Texas
C #552
