WD questions
Clifford Johnse
01-08-2007 08:57:16
1. In the gasket kit for the WD oil pan, I see two smaller half circle felt gaskets. THey are the same size as the crankshaft (1954). Are these rear main seals?
2. When mounting the flywheel back onto the engine crankshaft, do the 4 bolts need to be torqued to a certain specification? If so, how many psi?
old
01-08-2007 09:48:17
 Re: WD questions in reply to Clifford Johnsen, 01-08-2007 08:57:16
Torque the flywheel botls to 95-105 FT/lbs as per the I-T manual
