Backfire question
John
09-16-1999 09:35:12
My D17 runs{or seems to run} real good. The only thing is that at an idle it pops and backfires sporadically. Has anybody got any ideas where to check first without just doing a complete tuneup? thanks
Brian
09-21-1999 06:35:30
 Re: Backfire question in reply to John, 09-16-1999 09:35:12
Check that dist shaft for looseness. If it is, a quick easy fix is drive out the bushing in the distributor, cut it in half, reverse the pieces and reinsert. My local AGCO dealer told me that one. New bushings are about $50. Second, check your plug wires. In the dark you can see if they are cross firing due to insulation breakdown. Finally make sure the timing is correct. It will run fairly well but still have that occasional miss if its too far advanced. Hope this helps, Brian
Doug Morrow
09-20-1999 12:15:27
One possibility is a worn distributor shaft. Check it for play before you spend a lot of money on something else.
