broken sleeve in WD
Red48m
01-07-2007 19:09:57
I'm not much of a allis man, but a while back I drug home a '52 allis WD. I pulled the head and found a broken sleeve in the #3 hole. Is it possible that the block is ok and just needs a complete overhaul or should I start looking for a new block. I wont be near the tractor for a while, but I'm trying to order parts so I can get it going quick. Thanks
David Maddux
01-08-2007 13:34:12
 Re: broken sleeve in WD in reply to Red48m, 01-07-2007 19:09:57
If it broke due to frozen water in cylinder, it probably broke where there was no support of the block, therefore the block will be ok.
Ted in NE OH
01-08-2007 06:25:53
Yes, it is possible that the block is ok. You won't know until you pull the sleeve. Don't worry about any cracks at the top between cyclinders as the head gasket will seal those. Good luck.
