Well I'm/it back to the drawing board part 2
old
01-07-2007 13:35:03
Well I finally got things all worked out on my 3 point for my C. I used a WD cylinder, part of a stock cultivator lift, 2N ford 3 point arms, and some steel I had laying around. I have it set up so I can adjust the cylinder lift point and arm hook up points so if I need more lift I can get it just by moveing a oin or 2. I just tried it out a few minutes ago with a back blade and it works good other then I hate nonlive hyds
gary case
01-07-2007 14:28:25
 Re: Well I'm/it back to the drawing board part 2 in reply to old, 01-07-2007 13:35:03
hi old, sounds a little like my B. i did the samething. arm here and a pin here,i used a CA clyc. on mine. haven't tried picking anything up yet. i tried that advice for plugged jet in my carb AC B POP'IN you gave me and it was good advice, cause it did need need it. broke off 3 screws,fixed that, and made a new gasket. NOW THAT TOOK 3 TRYS man i was going to wait til tommorrow, but couldn't and finally got it. no leaks and the carbs all new looking. but i still got poping and back fire. maybe check align. on mag gears? thanx gary
old
01-07-2007 15:26:10
 Re: Well I'm/it back to the drawing board part 2 in reply to gary case, 01-07-2007 14:28:25
You might try moveing the mag timing a little bit advance or retard before you check the gears. I still have a little fine tuning on my 3 point to have it 100% done but not much. Then the fun begins, I have a friend that has his C sitting here and he saw the front lift and 3 point on my C and now I get to make him a fron lift and a 3 point for his C. So my set up is a prototype I guess
TxAllisMan
01-07-2007 17:48:09
 Re: Well I'm/it back to the drawing board part 2 in reply to old, 01-07-2007 15:26:10
Hey Old how about a few pics of your progress
Would like to see where your mounted the lower lift arms from the 2N.
Damon
N.E. Texas
old
01-07-2007 18:30:18
 Re: Well I'm/it back to the drawing board part 2 in reply to TxAllisMan, 01-07-2007 17:48:09
I'll try to explain it to you. Picture maybe in a few days when the fine tuneing is done. As your looking from the back the 2 frame rails under the seat, I mounted 2 pieces of 2X2X6 inch angle iron and on those mounted bolt on type hitch pins, the ones like used on blades etc. That gives me a good bit of lift and also lets thearms drop down low enough to be able to hook things up easy if on the ground.
Brandon P. Weber
01-07-2007 19:42:50
 Re: Well I'm/it back to the drawing board part 2 in reply to old, 01-07-2007 18:30:18
While you're on the subject of 3pt hitches, any suggestions on how to make the arms on them lower faster? My B/C hybrid has a 3pt hitch from a previous owner. Not being live hydraulics, it doesn't like to lower very well with light equipment on it; i.e. plow, bale forks, etc. I thought about garage door springs for some added tension, but I can't find anywhere to mount them where they'll actually make it pull in the right direction and/or be out of the way. Any thoughts?
old
01-07-2007 20:30:37
 Re: Well I'm/it back to the drawing board part 2 in reply to Brandon P. Weber, 01-07-2007 19:42:50
What size hyd hoses doe it have on it?? If the hose is say the normal 1/4 inch if you go to a 3/8 or 1/2 inch that might help. On my set up it would be easy to put springs on but thats my set up
