AC B Weights
Brandon P. Webe
01-05-2007 04:40:37
My little bastardized B/C is a little too light in the front end for my liking. Someone before me put chloride in the front tires and it still likes to come off the ground with a brush-hog or just about any other application for that matter. Are there AC front wheel weights or front frame weights available? Does anyone know where I could find some? I'd like something aesthetically pleasing before I go bolting a bunch of scrap iron to the old girl. Thanks.
Eldon (WA)
01-05-2007 19:58:38
 Re: AC B Weights in reply to Brandon P. Weber, 01-05-2007 04:40:37
I have a set of engine side weights and a set of "wishbone" weights (all factory) if you are interested. $200 each set. Email [email protected] - located near Spokane, WA
Rod (NH)
01-05-2007 11:18:57
Hi Brandon,
You can see the AC standard front axle weights on my B here. The standard engine side weights are shown here. I don't have any pictures of the front wheel weights. I don't know where you can find any of the weights. They do show up every once in a while but are pricey for what they are due to demand. The front axle weights seem to be more in demand and I have seen them go for more than $200, not including shipping, which can be a deal buster in itself due to the weight involved. You'll have to be lucky indeed to pick up any of the standard B weights at a reasonable price for a working tractor.
third party image Rod
old
01-05-2007 09:00:15
You need to build a set up like I did, thanks to Rod. He sent me pictures of a lift set up that A/C made for the B and with it on its easy to make sure the front end can't come up. This set up will lift around 500lbs and I have it set up with a blade for the front or I can drop the blade and lift things that need moved. Doesn't do as much as a loader but sure helps when you need to move the smaller stuff and saves the old bad back I have
John (C-IL)
01-05-2007 04:52:00
There are 3 kinds of weights. Engine side weights, front axle weights and front wheels weights. Some of them show up on ebay once in a while, the axle weights are available in the after market.
