wd, how much paint?
crock
01-03-2007 06:58:42
Is two quarts of paint enough to put a nice paint job on a wd?
Don L C
01-03-2007 22:11:47
 Re: wd, how much paint? in reply to crock, 01-03-2007 06:58:42
One gallon of paint and 3 qts. thinner....you should have some left over, but the cost of a gallon is about the same as 3 qts. .....
steve(ill)
01-03-2007 15:19:01
i normally buy a gallon since it is cheaper and have about a quart left. I use PPG automotive paint. Last forever, but the price is 3-4 times higher than farm store paint.
carl ac man
01-03-2007 16:40:00
 Re: wd, how much paint? in reply to steve(ill), 01-03-2007 15:19:01
i work in a body shop and if u use the right sealer (primer) ur farm store paint will last forever also at a fraction of ppg cost and if the paint does go bad its only 22 a gal so paint er again plus by the time ur farm store paint goes bad ur tractor is gonna look ratty and u might wanna repaint it again
carl
carl ac man
01-03-2007 14:29:45
i use two gallons of paint and i lay it on five coats and make it thick
i do three coats oneday then i do two coats the next day i put on one then wait till it is tacky then lay on a heavy coat to let it shine
IT WORKS!!!!! !
u just have to know how well ya paint and ur paint thickness
and i recomend van sickle paint frrom ace hardwear 22 a gal and u can paint ur tractor with a brush and not show a single bristle line just thin it down to water thinness
well its a lil more advise than ya expected but i hope it helps it works great for me aint had a unsatisfied coustomer yeet!!!!
carl
old
01-03-2007 09:28:46
I used a gallion of paint on my WC Speed Patrol and almost didn't have enough to do the whole job. Plus buying a gallion is cheaper in the long run then buying it by the QT. Picture of the speed patrol in in the web site
