ac d17popping out of 4th
curtisd17
01-01-2007 10:38:01
Ac d17 pops out of 4th gear is this an exspensive repair? Must tractor be split to install the part or make the adjustment?
Hurst
01-01-2007 12:37:13
 Re: ac d17popping out of 4th in reply to curtisd17, 01-01-2007 10:38:01
I may be wrong, but on allis tractors, I think 4th gear popping out can also be caused by the input shaft bearing. Also, 4th gear, if the splines are worn off, may require a new input shaft. Hopefully someone can verify.
Hurst
John (MO)
01-01-2007 11:29:27
All depends on what the problem is. If it is just the forks that are worn or bent a little and not pushing the gears all the way into place, then you don"t have to split the tractor. Just rebuild or replace the forks. If the gears are warn enough that they disengage, then you have to split the tractor and the gears are pretty expensive. We"ll hope for the former rather than the latter for your sake.
