wd45 shifter
crocker
12-31-2006 16:09:03
I have a 1952 wd45. The shifter handle is straight, it is not curved back? Is the straight handle original?
crocker
01-01-2007 18:22:17
 Re: wd45 shifter in reply to crocker, 12-31-2006 16:09:03
Thanks for the help. Much appreciated.
JMS/MN
01-01-2007 11:11:00
Original. They do not interchange. First curved shifter came in 1952 at serial number 127008. It was still a WD. 1952 WD production went from 105182-131242. 1953 WD production was 131243-146606. WD45 started in 1953 at serial number 146607.
Len Hoops
12-31-2006 16:22:01
If it's a 1952, it's a WD, not a WD45 and it would have a straight shift lever.
old
12-31-2006 16:20:46
From what I understand they didn't make the WD45 tills 53 or 54. I would say you have either a WD or if you don't have the cover plate on the right side of the engine a WD with a WD45 engine in it. The engines will bolt right in. Either way it sounds like you have a WD rear end at least
crocker
01-01-2007 15:10:55
 Re: wd45 shifter in reply to old, 12-31-2006 16:20:46
My 1952 wd or wd 45 with the straight shifter does have the cover on the right side of the motor. So does that make it a 52 wd chassis with a wd45 motor? If it will help the serial# is 121129.
Thankyou
old
01-01-2007 15:41:36
 Re: wd45 shifter in reply to crocker, 01-01-2007 15:10:55
Thats makes it a WD with a WD engine in it. The WD45 engine is the one that doesn't have the side plate on the right side. So you have a 1952 WD which is around 34HP. The WD45 is about 43HP
