Rebuilding a 1937 M water pump question
D2G2
12-30-2006 16:01:14
Water pump on my M suddenly sprang leak from the front of the shaft, I pulled the pump thinking that I could try replacing the o-ring, but I can"t get the fan hub off. The manual and part books show a "groove pin" through the hub but I can"t seem to find it, I"ve tried sanding the hub, painting with dykem blue, and then sanding again to see if I could spot the outline of the pin on the outer hub flange, is there something I am missing here? I also tried just pulling the hub thinking that maybe this one was pressed on and didn"t have a pin. If I can"t fix this one will one from a UC work? Thanks Glenn
TXAllisMan
12-31-2006 09:24:30
 Re: Rebuilding a 1937 M water pump question in reply to D2G2, 12-30-2006 16:01:14
third party image
Is this what your water pump looks like? If so theres one for sale on EBAY.
